question
Mohit G. avatar image
Mohit G. asked ·
Extract request attribute data using rest API
Hi All,
I have created some request attributes and plotted them in the multidimentional charts like below
Now I want to extract this data and store it in ELK for analysis and reporting purpose. Now I am looking for a API to extract data from request attribute.
Do let me know if this is available and fessable as I am unable to find any API for the same.
Mohit
dashboardrest apirequest attributes
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
It is not possible for now. Those data are calculated dynamically based on transaction data. They are not stored in DT Cassandra so you cannot export them in API. In January 2020 there will be option of creating custom metrics based on those data. Then you will have option to export them via API.
https://www.dynatrace.com/news/blog/custom-metrics-for-services-enrich-dynatrace-ai-and-dashboarding-capabilities-eap/
Here you have some details.
There was webinar as well which should be available soon on DT YouTube channel.
1 comment Share
Hi Sebastian,
Thanks for the clarification, so I need to wait for the custom metrics to be available for this.
Mohit
0 Likes 0 · ·
