Azure metrics available in DT
suresh230591
Mentor
We have azure integration with Dynatrace. However, we are not able to see all metrics available on Azure side in DT. Is there a specific reason these metrics dropped. Availability is very critical metrics for storage and we can't this in DT. There is no metrics available for storage at account level. Find below list of metrics we are interested.
Service typeMetricMetric Display NameUnitAggregation TypeDescription
storageAccountsAvailabilityAvailabilityPercentAverageThe percentage of availability for the storage service or the specified API operation. Availability is calculated by taking the TotalBillableRequests value and dividing it by the number of applicable requests, including those that produced unexpected errors. All unexpected errors result in reduced availability for the storage service or the specified API operation.
storageAccountsUsedCapacityUsed capacityBytesAverageAccount used capacity
storageAccountsIngressIngressBytesTotalThe amount of ingress data, in bytes. This number includes ingress from an external client into Azure Storage as well as ingress within Azure.
storageAccountsEgressEgressBytesTotalThe amount of egress data, in bytes. This number includes egress from an external client into Azure Storage as well as egress within Azure. As a result, this number does not reflect billable egress.
storageAccounts/blobServicesAvailabilityAvailabilityPercentAverageThe percentage of availability for the storage service or the specified API operation. Availability is calculated by taking the TotalBillableRequests value and dividing it by the number of applicable requests, including those that produced unexpected errors. All unexpected errors result in reduced availability for the storage service or the specified API operation.
storageAccounts/fileServicesAvailabilityAvailabilityPercentAverageThe percentage of availability for the storage service or the specified API operation. Availability is calculated by taking the TotalBillableRequests value and dividing it by the number of applicable requests, including those that produced unexpected errors. All unexpected errors result in reduced availability for the storage service or the specified API operation.
skrystosik
The question is if you try using credentials that you have provided into dynatrace to query Azure API, metrics are available? We see same situations for AWS for example, DT has defined plenty of metrics but only some of them has data.
Regards, Sebastian
ctturner
Inactive
@Suresh K. Dynatrace is making progress on the data surrounding Azure, I'd say Q1, Q2 you might see a release with more data surrounding Azure.
