question
Vlad S. avatar image
Vlad S. asked ·
USQL alerting
Hi gents
Is it possible somehow using native Dynatrace possibilities to raise the Problem (send alert) if some value, which we are getting by USQL query breaches the threshold?
The case: Unsuccessful placing order by users more than 10 per X minutes - Open the problem
It looks like now we have possibility to create custom alerts based only on timeseries data, but not on EUM data (Elastic)
alertingRUM
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
So far it is not possible. You need option to create custom metric based on USQL result, than you will be able to define threshold on this value. It’s kind of point for product idea :)
4 comments Share
You know, it sounds kinda strange to write the plugin which gets some value from one Dynatrace storage location, and put it to another :)
0 Likes 0 · ·
Not actually, DT needs to allow such option. The same story is with making custom metrics based on transactional data from multidimensional analysis which will be available next year.
USQL results are not stored anywhere as calculated data that can be analysed by AI engine. It's calculated live while you are fetching data based on data related to user sessions.
0 Likes 0 · ·
Still, alerting on USQL results is useless unless we can query live session data with USQL. Sessions may take minutes to hours to be closed and included in the results.
0 Likes 0 · ·
yes, and this is another topic. Session properties are not planned for live sessions afaik.
0 Likes 0 · ·
