Analysing .net memory dumps
ynias_reynders
Participant
In AppMon after taking a memory dump the client itself would also analyse the memory dump. This feature isn't present in the current Dynatrace. At the moment I've tryd to use Microsoft Debug diagnotstic tool without success. Also I've seen superdump: https://github.com/Dynatrace/superdump but the prerequisites are pretty big (docker container, ... ). Are there any other ways to analyse .net memory dumps that you've found successfull?
Joe_Hoffman
Dynatrace Leader
Dynatrace Leader
.NET memory dumps should be consumable by Visual Studio. Did you try VS and what was the error/issue?
DavidF
Participant
I also miss that Appmon memory analysis feature dearly. Very handy feature for on the fly memory leak analysis. Please bring it back Dynatrace!
