Cluster ActiveGate hardware sizing for Mainframe monitoring
jose_damian_rui
Organizer
Are there any calculator estimator for Cluster ActiveGate hardware sizing for Mainframe monitoring ?
Many Thanks
4 REPLIES 4
skrystosik
There is no calculator, most of the time those requirements are fine:
https://www.dynatrace.com/support/help/shortlink/activegate-requirements#hardware-requirements
I think you will have to check it manually with starting point mentioned here. If you are aware about amount of data than you can add 2 extra cores. If you have virtualised environment you should be able to scale up if you will need.
Regards, Sebastian
Thank you Sebastian,
- 1. Even for Mainframe monitoring , can we consider this approach ?
- 2. And for Dynatrace Managed installation hardware, are there any guidelines for Mainframe monitoring ? (I'm looking forward for something similar to this but for mainframe systems : https://www.dynatrace.com/support/help/setup-and-configuration/dynatrace-managed/installation/dynatr... )
Many Thanks
I've answered in second question of yours
Regards, Sebastian
And here is a link to it for the future reference 🙂
https://community.dynatrace.com/spaces/482/dynatrace-open-qa/questions/231943/activegate-hardware-si...
If you have any questions about the Community, you can contact me at maciej.neumann@dynatrace.com
