Reason why Problem changed from "Open" to "Close"
Shirai
Helper
In our customer's system, IIS packet retransmission rate jumped to 67%, and Dynatrace opened Problem. The packet retransmission rate dropped slightly, but a high retransmission rate of 56% continued. However, Dynatrace has closed the Problem. I want to know why Dynatarce closed Problem.
T.Shirai IIM Corp. Osaka Japan
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
Could you check if the default threshold for packet retransmission events was overwritten by a configuration. See below:
It is set to "automatically".
