visits from purepath
jose-antonio_ra
Inactive
Hi all.
it is possible to know the user session from a purepath?
Or can you know what is the visit that has connected this purepath?
thanks in advanced.
Jose A
3 REPLIES 3
Babar_Qayyum
Hello @Jose R.
I guess this could be possible if you are capturing something from the request attributes, for example, the User ID.
Babar
skrystosik
As Babar said, it's not possible out of the box right now by direct linking. you can only go down form visit / user action to purepath, not backwards. You can always view backtrace for purepath, it may present you which user action it was (name) but you will not have still direct link to user session, it is only information about which action was the trigger.
Regards, Sebastian
jose-antonio_ra
Inactive
thank you both for your answers
