monitoring RabbitMQ prerrequisites
jose-antonio_ra
Inactive
Hi all.
The rabbitmq monitoring prerequisites https://www.dynatrace.com/support/help/shortlink/rabbitmq-monitoring#prerequisites
indicate:
  • A single RabbitMQ cluster
Why is that so?
thanks in advanced.
Jose A
skrystosik
You have to have agent installed on RabbitMQ host to enable this plugin. In such case it can connect to only single instance per host. If you have 5 hosts with rabbit mq with agent available on all of them you can monitor all instances.
Regards, Sebastian
