Handle open files for ActiveGate system requirements on Windows
TatpongW
Frequent Guest
In Document, System requirements of ActiveGate. There are handle of open files that must least 500000 files but it has only for Linux OS. I want to know about Windows OS, is it must least 500000 like Linux? and how can I check the system limit for Windows?
Tatpong
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
No, it doesn’t affect default a Windows installation unless it was modified.
Windows Servers have limitations on maximum connected users and maximum open files per session. These are default settings:
  • Maximum Logged On Users: 16777216
  • Maximum open files per session: 16384
You can view them with net config servercommand.
Senior Product Manager,
Dynatrace Managed expert
