Cordova - Hybrid Mobile App Monitoring
Babar_Qayyum
Dear All,
It is my first encounter with the Cordova for the Hybrid Mobile App monitoring.
I wanted to know/clarify a few following basic configuration options:
  • Do we need to put the publicly available URL in the following configuration?
  • Do we need to add manually following JavaScript as the first script that executed during the page load cycle?
  • Which JS is better between JavaScript tag and OneAgent JavaScript tag?
Babar
3 REPLIES 3
Patrick_H
Dynatrace Champion
Dynatrace Champion
FYI @Matthias H.
iOS help: https://www.dynatrace.com/support/help/shortlink/ios-hub
matthias_hochri
Dynatrace Pro
Dynatrace Pro
Is there any reason you don't want to use the Dynatrace Cordova Plugin? (https://www.npmjs.com/package/dynatrace-cordova-plugin) - Because this plugin is doing everything out of the box and should answer all of your questions.
Hello @Matthias H.
The use case is to produce a dynatrace.config file and give it to the consultant (who builds the mobile application) for the instrumentation.
I already shared the Dynatrace Cordova Plugin with them, and now I will have to generate the proper dynatrace.config to give them for the instrumentation and testing.
Babar
