Search for a specific string on a web page
terrym
Newcomer
We would like to be able to check for a specific text string on a website to confirm the website is up and serving the correct pages. e.g. we put a maintenance page on a webserver so the normal content was not available but obvisouly the webserver appears to be up as the webserver was serving documents albeit it a maintenance page.
If we could search for a specific text string which is normally on the web page we know the correct content is being serverd. Hope that makes sense.
Can this be done with Dynatrace please?
arturo_mondelo
Dynatrace Advisor
Dynatrace Advisor
For this use case i would use a synthetic test (browser) that allow you to search for a specific content/text on a concrete page (step).
If the test is not found, an outage can be defined and you will get notified if you wish so!
Hope i understand your use case properly!
Thank You Arturo. This confirms I was on the right path.
