Does Dynatrace Managed need another Oracle Java Licenses?
willie_liu
Participant
Hey Team,
If subscribed Dynatrace Managed, would I need to buy the Oracle Java Licenses?
skrystosik
You don’t need Oracle Java liceses because of using monitoring. DT is using Open JDK. If you are talking about licenses related to monitoring, DT for server side monitoring has only one licensing type which is made based of RAM on monitored and it’s not related to technology.
Regards, Sebastian
Dear Sebastian,
Thanks A Lot.
