DEM Units Consumption for User sessions
sitinoor_wahab_
Newcomer
I want to calculate the total DEM Units consumptions for User Sessions, Session Replay disabled.
Please advise how can I get this info.
Thanks.
W. Norisz
3 REPLIES 3
vladislav_samoy
Inactive
Hi
There is a spesial metric for this in Billing section. It will help you
yasmeen_hazy1
Dynatrace Helper
Dynatrace Helper
Hi Norisz,
You can use this table to work out your consumption of DEM units:
You can find all licensing information on this documentation:
https://www.dynatrace.com/support/help/reference/monitoring-consumption-calculation/
sitinoor_wahab_
Newcomer
Thanks @Yasmeen H. and @Vlad S.
I am now managed to pull out the info from the custom chart.
Thank you!
