Is supported Dynatrace nodes and active gates installation on PaaS (OpenShift) platform ? Pro/Cons ?
jose_damian_rui
Organizer
Hello all.
We are evaluating to install Dynatrace on PaaS.
So:
Pro/Cons of the Dynatrace(nodes and actives gates) installation on Onpremises/OpenShift?
I really appreciate your feedback and references.
Many Thanks!
Damián
3 REPLIES 3
Julius_Loman
DynaMight Legend
DynaMight Legend
As far as I know - Dynatrace cluster nodes are not supported to be running in containers on any platform.
ActiveGate is also at the moment not supported running in containers, but I remember this is being worked on.
Many Thanks Julius.
I'm looking for a reference in the dynatrace website where is reflected that is not supported but not success for now.
Kind regards.
Damián
It's here:
https://www.dynatrace.com/support/help/shortlink/managed-requirements#system-requirements
You need a 64-bit Linux distribution (see supported Linux distributions below). Note that installation on both physical and virtualized hosts is supported, but installation in containers isn't supported.
