LDAP + Local Account
Babar_Qayyum
Dear All,
Can we have LDAP + Local accounts together?
The use case is to create a local account for the dashboards without password expiries and also for the outside consultants.
Babar
3 REPLIES 3
skrystosik
Only super admin account can be local when LDAP is enabled. Did you consider publication dashboard via url without authentication?
Regards, Sebastian
Hello @Sebastian K.
Yes, we are using this feature even though customer needs the provision of the local accounts. Unfortunately, we cannot provide super admin credentials to consultants.
Babar
You should start RFE then.
Regards, Sebastian
