dotted line from Process to Service
SB_12
Organizer
Hi , does any one know what represents dotted line in following screenshot
jonathan_schull
Dynatrace Advisor
Dynatrace Advisor
Hi Swati,
The dotted line means there have been no requests between the two entities in 2+ hours. After 72 hours, if there are still no requests between the two, the connection is "aged out" and will no longer be shown on the smartscape.
You can read more about the smartscape and how data is displayed in it here: https://www.dynatrace.com/support/help/how-to-use-dynatrace/smartscape/visualize-your-environment-to...
Cheers,
Jonathan
