How long cached for keep data if an agent on mobile can't connect Dynatrace server?
If the agent on mobile it can't connect Dynatrce mobile or mobile offline. How long it will keep data on cached?
skrystosik
It doesn’t matter because Dynatrace server is not accepting data older than 10 minutes. So this is max time you can get without internet connection.
Regards, Sebastian
Hello Sebastian K.
Thank for your comment, Do you have a document about that?
