what is the difference between CPU Usage and CPU System in Dynatrace?
ChadTurner
DynaMight Legend
DynaMight Legend
@Chakravarthula P. CPU usage is the total amount of CPU used on the server selected. CPU System is the amount of CPU that the Operating System is using. You will find that Linux Devices have more in the legend then the windows devices:
If you add everything up under Idle, the percentage should equal the usage metric.
-Chad
image didnt attach correctly
-Chad
