Can oracle replace VMware?
ratchanad
Participant
I want to know dynatrace can connect your Oracle VM server?
ratchanad
Participant
i need connect to this picture.(VMware change Oracle).
alonso_decosio
Inactive
If you are referring to get data from Virtualbox, no.
Dynatrace is pulling VMware the metrics with a plugin that is running on the ActiveGate and currently there isn't a similar one for Oracle.
