• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home
  • Public Forums
  • Dynatrace
avatar image
Question by Janne O. · Feb 05, 2020 at 07:31 AM · dynatrace saas activegate
Downloading agents trough Environment ActiveGate in SAAS version
Dear All,
Since I'm getting little bit mixed information I would like to have information from all of you guys about this topic.
We are using SAAS version of Dynatrace and trying to figure out that can we download agents trough the environment ActiveGate? I got information from support that the environment ActiveGate does not contain the agent installation packages and therefore we can't download the agents trough environment activegate.
I know that this is possible in Managed environment trough the Cluster ActiveGates but seems that we can't make the agent download process trough the environment ActiveGate?
Our case is that the monitored hosts do not have internet connection and that's why we would like to route the download process trough the environment ActiveGate. But if this is not possible we just need to think about some other solution.
Just would like to have comments from community is that possible to download the agents trough environment ActiveGate or not.
Br,
Janne
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Best Answer
Answer by Christian W. · Feb 05, 2020 at 12:11 PM
Hello Janne,
you should be able to download the agent from the internet and then transfer the file to your client/environment and continue with the installation.
C.
Comment
0 Show 2 · Share
avatar image Janne O. · Feb 05, 2020 at 02:01 PM 0
Share
Thank you for the suggestion @christian w. and we know this possibility also.
From our perspective it would actually be easier if we could route the agent download trough the ActiveGate than manually copying the installation packet to servers.
If the agent download cant be done trough the ActiveGate we just need to think about setting up proxy or something else.
br,
Janne
avatar image Yos N. Janne O. · Feb 06, 2020 at 07:54 AM 0
Share
This one should become a RFE and not only for SaaS
Yos
avatar image
Best Answer
Answer by Dallas P. · Feb 06, 2020 at 10:23 PM
Hi Janne,
Yes, you are able to download an agent through the activegate if you have access from your local machine to the ActiveGate.
First go to the "Deploy Dynatrace" and "start installation" then select linux. Take the wget command it gives you and alter it with the activegate IP over port 999 (which is the default communication port). Your environment_ID can be gathered from your tenant URL (example: <environment_ID>.live.dynatrace.com)
I believe that you should take your URL and make it look like this:
wget -O Dynatrace-OneAgent-Linux-<Version_here> "https://<ActiveGate_IP_Address:9999>/e/<environment_ID>/api/v1/deployment/installer/agent/unix/default/latest?arch=x86&flavor=default" --header="Authorization: Api-Token - xxxxx"
Make sure to add the /e/<environment_ID>
I just tested this on my SaaS environment and it works like a charm.
-Dallas
Comment
Janne O.
Yos N.
Maciej N.
Jonny S.
Benjamin W.
5 Show 2 · Share
avatar image Janne O. · Feb 07, 2020 at 11:07 AM 2
Share
Hi @Dallas P.,
Thank you so much and you solved our case.
I totally forgot the environment ID from the URL and it's quite obvious that the download was not working without it. With the ID everything is working as expected with downloading the agents trough the ActiveGate.
-Janne
avatar image Dallas P. Janne O. · Feb 07, 2020 at 05:55 PM 1
Share
Hey Janne,
Glad to help!
-Dallas
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
28 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
Default user credentials for Dynatrace oneagent
Dynatrace : Compatibility of the old version agent with Updated active gateway version
Active gate in DMZ using proxy
Communication between OneAgent&ActiveGate, between ActiveGate&Dynatrace, and also between Dynatrace&MissionControl. Are they bi-directional or uni-directional?
ActiveGate with Proxy Installation Error
Forum Tags
mobile monitoring dotnet iis chat kubernetes servicenow amazon web services feedback mysql mainframe application rules rest api cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo activegate auto-detection high five award uem webserver usql iib test automation license ios news migration management zones ibm mq web services notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai availability tipstricks automation extensions diagnostic tools session replay permissions search davis assistant auto-update faq documentation problem detection http monitors easytravel apdex network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration production user actions postgresql synthetic locations upgrade oneagent security Dynatrace Managed user management python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting performance monitoring NGINX action naming linux nam installation error reporting database mission control apache mobileapp RUM php azure purepath davis scripting aix nodejs android
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
