DT integration with CA-SDM
marcelo_souto1
Visitor
Good Morning,
I wonder if anyone has already integrated DT managed with CA Service Desk.
Ticket opening and closing.
abraham_villega
Dynatrace Participant
Hi Marcelo,
We currently don't have a direct intgration wit CA-SDM.
What you can do is a custom integration going to Settings>Integration>Problem notifications>Set up notifications> Custom Integration.
Right there you can integrate problem notification with Third Party Systems. The only thing you need is a webhook. In addition you can add additional headers and customize the Payload.
Here is a reference:
https://www.dynatrace.com/support/help/setup-and-configuration/integrations/third-party-integrations...
Abraham
