Disk space required for OneAgent on Solaris
jeff_rowell
Helper
The Dynatrace documentation for installation on Solaris has a link to disk space requirements, however, this link takes you to a page that provides info for AIX. Can somebody please tell me how much space is required to install the agent on Solaris?
The documentation link I refer to above is:
https://www.dynatrace.com/support/help/technology-support/operating-systems/solaris/installation/ins...
3 REPLIES 3
skrystosik
It should be similar to AIX. You can always use built in chat and contact Dynatrace One guys, they may be able to help you save some space 🙂 (as documentation says).
Regards, Sebastian
Joe_Hoffman
Dynatrace Leader
Dynatrace Leader
Thanks Jeff for pointing out the doc page issue. I've submitted a change request for our doc team to get this doc page clarified.
Over a year later, looks like it still hasn't been fixed... I also just submitted a request to fix it via the site's feedback function.
