monitoring obsolete version of operating system
jose-antonio_ra
Inactive
Hi all.
We have a client with some servers in Linux RH 5. There is some way to monitor them, for example some infrastructure plugin .....
thanks
Jose A
7 REPLIES 7
rastislav_danis
DynaMight Pro
DynaMight Pro
https://www.dynatrace.com/support/help/technology-support/supported-technologies-and-versions/ says:
RH 5.4+ is supported with disabled SELinux
Alanata a.s.
I can confirm. We do have a customer running RH 5.x, even the uncommon 32-bit version. It is supported with disabled selinux and with appropriate version of glibc that comes with RHEL 5.4+
ChadTurner
DynaMight Legend
DynaMight Legend
I would give it a shot with the Oneagent, If you have an older version you could even give that a shot. If those options fail you could always try agentless monitoring. Its worth a shot, it might work and it might not.
-Chad
thanks Chad, is there any documentation abaout this?
install agentless, configuration,...
besta regards
jose A
but this AMD is part of DCRUM/NAM not dynatrace !
Alanata a.s.
@Rastislav D. Ano
-Chad
