X-dynatrace header getting removed from tomcat process
mayana_s_khan
Inactive
The hybris tomcat process is successfully instrumented with dynatrace and it not showing any errors.
But when i goto transactions its showing as opaque service and the X-dynatrace header is not available in the purepath.
we have checked the pod have all the permissions, the tomcat service is running on Azure kubernetes cluster. Also we don`t have any errors in bootstrap logs.
Did anyone face the similar issue?
skrystosik
Did you check support archive? It seems that instrumentation wasn’t be done properly.
Regards, Sebastian
