Error message when uninstalling Oneagent
Shirai
Helper
An error message was displayed when uninstalling Oneagent Linux.
Confirmed that "semanage" is not installed.
Is the uninstallation successful?
[root@ket-bat11 agent]# /home/dynatrace/agentuninstall.sh/uninstall.sh
16:55:05 Checking root privileges...
16:55:05 OK
16:55:05 Removing entries for preloading
16:55:05 Using SysV to stop the agent
16:55:12 Removing Dynatrace OneAgent from autostart
16:55:12 Removing oneagent from /etc/init.d
16:55:12 Removing oneagentproc from system folders
16:55:12 Removing oneagentproc from /lib
16:55:12 Removing oneagentproc from /lib64
16:55:12 Cleaning up /opt/dynatrace/oneagent/agent. Part of configuration preserved in /var/lib/dynatrace/oneagent
/home/dynatrace/agent/uninstall.sh: line 465: semanage: Command not found
16:55:12 Removing Dynatrace SELinux policies.
16:55:14 Uninstallation finished successfully
T.Shirai IIM Corp. Osaka Japan
skrystosik
If script reached it's end (it is, you see it in last line) in general everything should be uninstalled properly.
Regards, Sebastian
bartosz_pollok
Dynatrace Enthusiast
Hello Toshimasa,
The OneAgent uninstallation is indeed finished, but due to the error you see in the output, i.e. lack of semanage utility on your host, the uninstall script wasn't able to remove SELinux context for your custom-path OneAgent installation.
The last thing to complete the uninstall in this case is to install semanage utility onto your host and use it to remove OneAgent contexts manually. You can find out how to do that using semanage docs (e.g. execute man semanage on your machine).
Bartek
