GKE OneAgent Do Not Send Data My Dynatrace ActiveGate
salih_pala
Newcomer
I have a problem and I want to ask you.
I installed OneAgent on Google kubernetes engine for to the information below.
https://www.dynatrace.com/support/help/technology-support/cloud-platforms/google-cloud-platform/google-kubernetes-engine/installation-and-operation/full-stack/deploy-oneagent-on-google-kubernetes-engine-clusters/
All pods seem to be working healthy. There is no error in his logs.
After this installation, I have reviewed the article below. I applied it later. When I add the kubernetes api and secret key on the Dynatrace homepage, I can see the cluster nodes. I see memory and cpu usage for my cluster nodes.. Its good.
https://www.dynatrace.com/support/help/technology-support/cloud-platforms/kubernetes/connect-kubernetes-clusters-to-dynatrace/
But I don't want to see this. I want to see my pods, services, communication with each other, apm data of my asp dotnet core application running in pods. however, no data on my pods appears on the Dynatrace. my pods, my services, nothing appears.
it only shows my node data in my cluster address which i added as api. it is already receiving node data via api, not oneagent. so the oneagent dynatrace doesn't seem to be sending data to my server.
.. Or data may be coming on Dynatrace. This may need to be activated by making a different setting.
Necessary information is given below. Please help me. where am i doing wrong
My gke cluster information;
Version: 1.13.12-gke.25
OS: Container-Optimized OS (cos)
Resources: Unlimited (autoscaling..)
..Installation Steps..
kubectl create clusterrolebinding cluster-admin-binding --clusterrole=cluster-admin --user=$(gcloud config get-value account)
kubectl create namespace dynatrace
LATEST_RELEASE=$(curl -s https://api.github.com/repos/dynatrace/dynatrace-oneagent-operator/releases/latest | grep tag_name | cut -d '"' -f 4)
kubectl create -f https://raw.githubusercontent.com/Dynatrace/dynatrace-oneagent-operator/$LATEST_RELEASE/deploy/kubernetes.yaml
kubectl -n dynatrace logs -f deployment/dynatrace-oneagent-operator
kubectl -n dynatrace create secret generic oneagent --from-literal="apiToken=xxxxxxx" --from-literal="paasToken=xxxxxxx"
curl -o cr.yaml https://raw.githubusercontent.com/Dynatrace/dynatrace-oneagent-operator/$LATEST_RELEASE/deploy/cr.yaml
cat cr.yaml
apiVersion: dynatrace.com/v1alpha1
kind: OneAgent
metadata:
namespace: dynatrace
spec:
apiUrl: https://public-ip/e/xxx-xxx-xxx-xxx/api
skipCertCheck: true
disableAgentUpdate: true
tokens: "oneagent"
tolerations:
- effect: NoSchedule
key: node-role.kubernetes.io/master
operator: Exists
image: "docker.io/dynatrace/oneagent"
env:
- name: ONEAGENT_ENABLE_VOLUME_STORAGE
value: "true"
args:
- APP_LOG_CONTENT_ACCESS=1
Results
NAME READY STATUS RESTARTS AGE IP NODE NOMINATED NODE READINESS GATES
dynatrace-oneagent-operator-87cdf56bf-894kt 1/1 Running 0 17h 10.8.5.62 gke-xxx-project-cluster--xxx-project-cluster--d72271ba-99rl <none> <none>
oneagent-drq2r 1/1 Running 0 17h 10.26.1.56 gke-xxx-project-cluster--xxx-project-cluster--d72271ba-99rl <none> <none>
oneagent-f76g8 1/1 Running 0 17h 10.26.1.55 gke-xxx-project-cluster--xxx-project-cluster--3e09354d-js1m <none> <none>
oneagent-fb4ww 1/1 Running 0 17h 10.26.1.54 gke-xxx-project-cluster--xxx-project-cluster--3e09354d-0wwv <none> <none>
oneagent-fp8kp 1/1 Running 0 17h 10.26.1.53 gke-xxx-project-cluster--xxx-project-cluster--d72271ba-3jkg <none> <none>
oneagent-l2l8x 1/1 Running 0 17h 10.26.1.57 gke-xxx-project-cluster--xxx-project-cluster--89fb277a-gvp4 <none> <none>
oneagent-m2v4v 1/1 Running 0 17h 10.26.1.51 gke-xxx-project-cluster--xxx-project-cluster--d72271ba-1b5r <none> <none>
kubectl get deploy,daemonset
NAME READY UP-TO-DATE AVAILABLE AGE
deployment.extensions/dynatrace-oneagent-operator 1/1 1 1 18h
NAME DESIRED CURRENT READY UP-TO-DATE AVAILABLE NODE SELECTOR AGE
daemonset.extensions/oneagent 6 6 6 6 6 beta.kubernetes.io/os=linux 18h
kubectl get deployment.extensions/dynatrace-oneagent-operator -o yaml
apiVersion: extensions/v1beta1
kind: Deployment
metadata:
annotations:
deployment.kubernetes.io/revision: "1"
kubectl.kubernetes.io/last-applied-configuration: |
{"apiVersion":"apps/v1","kind":"Deployment","metadata":{"annotations":{},"labels":{"dynatrace":"operator","operator":"oneagent"},"name":"dynatrace-oneagent-operator","namespace":"dynatrace"},"spec":{"replicas":1,"revisionHistoryLimit":1,"selector":{"matchLabels":{"name":"dynatrace-oneagent-operator"}},"strategy":{"type":"Recreate"},"template":{"metadata":{"labels":{"dynatrace":"operator","name":"dynatrace-oneagent-operator","operator":"oneagent"}},"spec":{"containers":[{"env":[{"name":"WATCH_NAMESPACE","valueFrom":{"fieldRef":{"fieldPath":"metadata.namespace"}}},{"name":"POD_NAME","valueFrom":{"fieldRef":{"fieldPath":"metadata.name"}}}],"image":"quay.io/dynatrace/dynatrace-oneagent-operator:v0.6.0","imagePullPolicy":"Always","name":"dynatrace-oneagent-operator","ports":[{"containerPort":60000,"name":"metrics"}],"resources":{"limits":{"cpu":"100m","memory":"256Mi"},"requests":{"cpu":"10m","memory":"64Mi"}}}],"nodeSelector":{"beta.kubernetes.io/arch":"amd64","beta.kubernetes.io/os":"linux"},"serviceAccountName":"dynatrace-oneagent-operator"}}}}
creationTimestamp: "2020-02-20T10:00:33Z"
generation: 1
labels:
dynatrace: operator
operator: oneagent
resourceVersion: "15912991"
selfLink: /apis/extensions/v1beta1/namespaces/dynatrace/deployments/dynatrace-oneagent-operator
uid: d54cccb5-53c7-11ea-9bfe-4201ac100009
spec:
progressDeadlineSeconds: 600
replicas: 1
revisionHistoryLimit: 1
selector:
matchLabels:
strategy:
type: Recreate
template:
metadata:
creationTimestamp: null
labels:
dynatrace: operator
operator: oneagent
spec:
containers:
- env:
- name: WATCH_NAMESPACE
valueFrom:
fieldRef:
apiVersion: v1
fieldPath: metadata.namespace
- name: POD_NAME
valueFrom:
fieldRef:
apiVersion: v1
image: quay.io/dynatrace/dynatrace-oneagent-operator:v0.6.0
imagePullPolicy: Always
ports:
- containerPort: 60000
protocol: TCP
resources:
limits:
cpu: 100m
memory: 256Mi
requests:
cpu: 10m
memory: 64Mi
terminationMessagePath: /dev/termination-log
terminationMessagePolicy: File
dnsPolicy: ClusterFirst
nodeSelector:
beta.kubernetes.io/arch: amd64
beta.kubernetes.io/os: linux
restartPolicy: Always
schedulerName: default-scheduler
securityContext: {}
serviceAccount: dynatrace-oneagent-operator
serviceAccountName: dynatrace-oneagent-operator
terminationGracePeriodSeconds: 30
status:
availableReplicas: 1
conditions:
- lastTransitionTime: "2020-02-20T10:00:33Z"
lastUpdateTime: "2020-02-20T10:00:43Z"
message: ReplicaSet "dynatrace-oneagent-operator-87cdf56bf" has successfully progressed.
reason: NewReplicaSetAvailable
status: "True"
type: Progressing
- lastTransitionTime: "2020-02-20T10:54:48Z"
lastUpdateTime: "2020-02-20T10:54:48Z"
message: Deployment has minimum availability.
reason: MinimumReplicasAvailable
status: "True"
type: Available
observedGeneration: 1
readyReplicas: 1
replicas: 1
updatedReplicas: 1
kubectl get pod
kNAME READY STATUS RESTARTS AGE
kubectl logs -f dynatrace-oneagent-operator-87cdf56bf-894kt
{"level":"info","ts":"2020-02-20T10:54:48.723Z","logger":"cmd","msg":"Go Version: go1.13.6"}
{"level":"info","ts":"2020-02-20T10:54:48.723Z","logger":"cmd","msg":"Go OS/Arch: linux/amd64"}
{"level":"info","ts":"2020-02-20T10:54:48.723Z","logger":"cmd","msg":"Version of operator-sdk: v0.12.0"}
{"level":"info","ts":"2020-02-20T10:54:48.723Z","logger":"cmd","msg":"Version of dynatrace-oneagent-operator: v0.6.0"}
{"level":"info","ts":"2020-02-20T10:54:48.724Z","logger":"leader","msg":"Trying to become the leader."}
{"level":"info","ts":"2020-02-20T10:54:49.223Z","logger":"leader","msg":"Found existing lock","LockOwner":"dynatrace-oneagent-operator-87cdf56bf-m5qpc"}
{"level":"info","ts":"2020-02-20T10:54:49.235Z","logger":"leader","msg":"Not the leader. Waiting."}
{"level":"info","ts":"2020-02-20T10:54:50.364Z","logger":"leader","msg":"Not the leader. Waiting."}
{"level":"info","ts":"2020-02-20T10:54:52.747Z","logger":"leader","msg":"Not the leader. Waiting."}
{"level":"info","ts":"2020-02-20T10:54:57.287Z","logger":"leader","msg":"Became the leader."}
{"level":"info","ts":"2020-02-20T10:54:57.619Z","logger":"controller-runtime.metrics","msg":"metrics server is starting to listen","addr":":8080"}
{"level":"info","ts":"2020-02-20T10:54:57.620Z","logger":"cmd","msg":"Registering Components."}
{"level":"info","ts":"2020-02-20T10:54:57.621Z","logger":"controller-runtime.controller","msg":"Starting EventSource","controller":"oneagent-controller","source":"kind source: /, Kind="}
{"level":"info","ts":"2020-02-20T10:54:57.621Z","logger":"cmd","msg":"Starting the Cmd."}
{"level":"info","ts":"2020-02-20T10:54:57.621Z","logger":"controller-runtime.manager","msg":"starting metrics server","path":"/metrics"}
{"level":"info","ts":"2020-02-20T10:54:58.022Z","logger":"controller-runtime.controller","msg":"Starting Controller","controller":"oneagent-controller"}
{"level":"info","ts":"2020-02-20T10:54:58.122Z","logger":"controller-runtime.controller","msg":"Starting workers","controller":"oneagent-controller","worker count":1}
{"level":"info","ts":"2020-02-20T10:54:58.123Z","logger":"oneagent.controller","msg":"reconciling oneagent","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:54:58.724Z","logger":"oneagent.controller","msg":"updating existing daemonset","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:54:58.823Z","logger":"oneagent.controller","msg":"automatic oneagent update is disabled","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:54:58.824Z","logger":"oneagent.controller","msg":"reconciling oneagent","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:54:58.824Z","logger":"oneagent.controller","msg":"updating existing daemonset","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:54:58.830Z","logger":"oneagent.controller","msg":"automatic oneagent update is disabled","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:55:33.777Z","logger":"oneagent.controller","msg":"reconciling oneagent","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:55:33.777Z","logger":"oneagent.controller","msg":"updating existing daemonset","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:55:33.790Z","logger":"oneagent.controller","msg":"automatic oneagent update is disabled","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:55:36.042Z","logger":"oneagent.controller","msg":"reconciling oneagent","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:55:36.043Z","logger":"oneagent.controller","msg":"updating existing daemonset","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:55:36.050Z","logger":"oneagent.controller","msg":"automatic oneagent update is disabled","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:55:39.261Z","logger":"oneagent.controller","msg":"reconciling oneagent","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:55:39.261Z","logger":"oneagent.controller","msg":"updating existing daemonset","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:55:39.270Z","logger":"oneagent.controller","msg":"automatic oneagent update is disabled","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:55:39.619Z","logger":"oneagent.controller","msg":"reconciling oneagent","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:55:39.620Z","logger":"oneagent.controller","msg":"updating existing daemonset","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:55:39.626Z","logger":"oneagent.controller","msg":"automatic oneagent update is disabled","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:55:44.282Z","logger":"oneagent.controller","msg":"reconciling oneagent","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:55:44.282Z","logger":"oneagent.controller","msg":"updating existing daemonset","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:55:44.296Z","logger":"oneagent.controller","msg":"automatic oneagent update is disabled","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:55:50.111Z","logger":"oneagent.controller","msg":"reconciling oneagent","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:55:50.112Z","logger":"oneagent.controller","msg":"updating existing daemonset","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T10:55:50.125Z","logger":"oneagent.controller","msg":"automatic oneagent update is disabled","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T20:54:57.723Z","logger":"oneagent.controller","msg":"reconciling oneagent","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T20:54:58.165Z","logger":"oneagent.controller","msg":"updating existing daemonset","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T20:54:58.170Z","logger":"oneagent.controller","msg":"automatic oneagent update is disabled","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T20:54:58.170Z","logger":"oneagent.controller","msg":"reconciling oneagent","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T20:54:58.170Z","logger":"oneagent.controller","msg":"updating existing daemonset","namespace":"dynatrace","name":"oneagent"}
{"level":"info","ts":"2020-02-20T20:54:58.175Z","logger":"oneagent.controller","msg":"automatic oneagent update is disabled","namespace":"dynatrace","name":"oneagent"}
^C
kubectl logs -f oneagent-drq2r
10:55:00 Using volume-based storage
10:55:01 Initializing volume-based storage from within the container
10:55:01 Detected volume management CLI tool: docker
10:55:03 Started agent deployment as a container, PID 3309698.
10:55:03 Downloading agent to /tmp/Dynatrace-OneAgent-Linux.sh via https://public-ip/e/xxx-xxx-xxx-xxx/api/v1/deployment/installer/agent/unix/default/latest?Api-Token=***&arch=x86&flavor=default
10:55:03 Download was skipped as the agent version did not change
10:55:03 Validating downloaded agent installer
10:55:08 Verification successful
10:55:09 Checking root privileges...
10:55:09 OK
10:55:09 Installation started, version 1.183.163.20200203-165724, build date: 03.02.2020, PID 3311177.
10:55:09 Detected platform: LINUX arch: X86
10:55:09 Detected bitness: 64
10:55:09 Starting agents...
10:55:09 OK
10:55:09 Starting Dynatrace OneAgent from within the container.
2020-02-20 10:55:09.894 UTC [89a6bd3e] info main: Logger initialized, local time is: 2020-02-20 10:55
2020-02-20 10:55:09.894 UTC [89a6bd3e] info main: -----------------------------------------------------------------------------
2020-02-20 10:55:09.894 UTC [89a6bd3e] info main: Dynatrace Watchdog, Copyright (C) 2012-2020 Dynatrace LLC. www.dynatrace.com
2020-02-20 10:55:09.894 UTC [89a6bd3e] info main: Dynatrace Watchdog version: 1.183.162.20200202-170257 - built 2020.02.02 17:02:57, SCM Rev. 2fc65a2385518553681f68c7b6d3924633d2a870
2020-02-20 10:55:09.894 UTC [89a6bd3e] info main: Application information:
2020-02-20 10:55:09.894 UTC [89a6bd3e] info main: Short name: oneagentwatchdog
2020-02-20 10:55:09.894 UTC [89a6bd3e] info main: Directory: /opt/dynatrace/oneagent/agent/lib64
2020-02-20 10:55:09.894 UTC [89a6bd3e] info main: Full path: /opt/dynatrace/oneagent/agent/lib64/oneagentwatchdog
2020-02-20 10:55:09.894 UTC [89a6bd3e] info main: Loging information:
2020-02-20 10:55:09.894 UTC [89a6bd3e] info main: Level console: 4 (info)
2020-02-20 10:55:09.894 UTC [89a6bd3e] info main: Level file: 4 (info)
2020-02-20 10:55:09.894 UTC [89a6bd3e] info main: Max log file age: 124 days
2020-02-20 10:55:09.894 UTC [89a6bd3e] info main: Max single log file size: 64 MiB
2020-02-20 10:55:09.894 UTC [89a6bd3e] info main: Filename pattern: $exename_$pid.log
2020-02-20 10:55:09.894 UTC [89a6bd3e] info main: Directory: /opt/dynatrace/oneagent/log/watchdog
2020-02-20 10:55:09.894 UTC [89a6bd3e] info main: Preferred log file: /opt/dynatrace/oneagent/log/watchdog/oneagentwatchdog_3309698.log
2020-02-20 10:55:09.894 UTC [89a6bd3e] info main: Log file: /opt/dynatrace/oneagent/log/watchdog/oneagentwatchdog_3309698.log
2020-02-20 10:55:09.895 UTC [89a6bd3e] info main: Invoked with command line: '/opt/dynatrace/oneagent/agent/lib64/oneagentwatchdog -vm=/opt/dynatrace/oneagent/agent/lib64/oneagentos -ini /opt/dynatrace/oneagent/agent/conf/ruxitwatchdog.ini'
2020-02-20 10:55:09.895 UTC [89a6bd3e] info main: Aging old log files
2020-02-20 10:55:09.895 UTC [89a6bd3e] info main: Memory limit calculated: 500 MiB + 5% of 7477 MiB = 873 MiB
2020-02-20 10:55:09.895 UTC [89a6bd3e] info main: Application arguments:
2020-02-20 10:55:09.895 UTC [89a6bd3e] info main: -timeout=900
2020-02-20 10:55:09.895 UTC [89a6bd3e] info main: -shutdowntimeout=60
2020-02-20 10:55:09.895 UTC [89a6bd3e] info main: -restartonfailure
2020-02-20 10:55:09.895 UTC [89a6bd3e] info main: -loglevel=4
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: -native=1
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: -nopassinitovm=1
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: -binaries=oneagentplugin;oneagentloganalytics;oneagentnetwork
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: -memorylimit.absolute=500
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: -memorylimit.percentage=5
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: -coredump.binary=oneagentdumpproc
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: -pidfiledir=/opt/dynatrace/oneagent/agent/conf/runtime
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: -log.name=$exename_$pid.log
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: -logdir=/opt/dynatrace/oneagent/log/watchdog
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: -portrange=50000:50100
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: -basedir=.
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: -vm=/opt/dynatrace/oneagent/agent/lib64/oneagentos
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: Java VM arguments:
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: -Dcom.compuware.apm.WatchDogTimeout=900
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: Java application arguments:
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: Internal settings:
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: ConfigFile=/opt/dynatrace/oneagent/agent/conf/ruxitwatchdog.ini
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: userconfigfile=/var/lib/dynatrace/oneagent/agent/config/watchdoguserconfig.conf
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: BasedirAbsolute=/opt/dynatrace/oneagent/agent/lib64
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: Unknown arguments:
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main: Watchdog initialization completed
2020-02-20 10:55:09.896 UTC [89a6bd3e] info oneagentos: Core dump generation configured to use /opt/dynatrace/oneagent/agent/lib64/oneagentdumpproc, storage path: default, timeout: 300 s
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main : Watchdog runtime configuration will be loaded from: /var/lib/dynatrace/oneagent/agent/config/watchdogruntime.conf
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main : Running in root mode
2020-02-20 10:55:09.896 UTC [89a6bd3e] info oneagentplugin: Core dump generation configured to use /opt/dynatrace/oneagent/agent/lib64/oneagentdumpproc, storage path: default, timeout: 300 s
2020-02-20 10:55:09.896 UTC [89a6bd3e] info oneagentloganalytics: Core dump generation configured to use /opt/dynatrace/oneagent/agent/lib64/oneagentdumpproc, storage path: default, timeout: 300 s
2020-02-20 10:55:09.896 UTC [89a6bd3e] info oneagentnetwork : Core dump generation configured to use /opt/dynatrace/oneagent/agent/lib64/oneagentdumpproc, storage path: default, timeout: 300 s
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main : Created pid file: /opt/dynatrace/oneagent/agent/conf/runtime/oneagentwatchdog.pid
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main : SuspensionDetector thread started
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main : Starting Watchdog, pid: 3309698
2020-02-20 10:55:09.896 UTC [89a6bd3e] info main : Signal handler configured
2020-02-20 10:55:09.897 UTC [89a6bd3e] info main : Entering main loop
2020-02-20 10:55:09.897 UTC [89a6bd3e] info main : Configuration file watchdogruntime.conf refreshed. New activation map:
2020-02-20 10:55:09.897 UTC [89a6bd3e] info main : oneagentloganalytics OFF
2020-02-20 10:55:09.897 UTC [89a6bd3e] info main : oneagentnetwork OFF
2020-02-20 10:55:09.897 UTC [89a6bd3e] info main : oneagentplugin OFF
2020-02-20 10:55:09.897 UTC [8830e87e] info oneagentos : Start main thread
2020-02-20 10:55:09.897 UTC [87b0f87e] info oneagentos : Trying to open port 50000
2020-02-20 10:55:09.897 UTC [87b0f87e] info oneagentos : Watchdog successfully opened listening port 50000
2020-02-20 10:55:09.897 UTC [87b0f87e] info oneagentos : BinaryWatcher thread started successfully, listening on socket 50000
2020-02-20 10:55:09.918 UTC [8830e87e] info oneagentos : BinaryWatcher initialized
2020-02-20 10:55:09.918 UTC [8830e87e] info oneagentos : Entering application restart loop
2020-02-20 10:55:09.918 UTC [8830e87e] info oneagentos : -----------------------------------------------------------------------------
2020-02-20 10:55:09.918 UTC [8830e87e] info oneagentos : Starting process
2020-02-20 10:55:09.918 UTC [8830e87e] info oneagentos : Launcher configuration summary for oneagentos
2020-02-20 10:55:09.918 UTC [8830e87e] info oneagentos : Binary: /opt/dynatrace/oneagent/agent/lib64/oneagentos
2020-02-20 10:55:09.918 UTC [8830e87e] info oneagentos : Working directory: /opt/dynatrace/oneagent/agent/lib64
2020-02-20 10:55:09.918 UTC [8830e87e] info oneagentos : Native watchdog enabled, port: 50000, timeout: 900 s (timeout for graceful shutdown: 300 s)
2020-02-20 10:55:09.918 UTC [8830e87e] info oneagentos : Memory usage limit: 873 MiB
2020-02-20 10:55:09.918 UTC [8830e87e] info oneagentos : Command line: /opt/dynatrace/oneagent/agent/lib64/oneagentos -Dcom.compuware.apm.WatchDogPort=50000 -Dcom.compuware.apm.WatchDogTimeout=900
2020-02-20 10:55:09.918 UTC [8830e87e] info oneagentos : Custom environment variables:
2020-02-20 10:55:09.918 UTC [8830e87e] info oneagentos : Process created successfully, pid: 3311904
2020-02-20 10:55:09.919 UTC [8830e87e] info oneagentos : BinaryWatcher activated
2020-02-20 10:55:09.919 UTC [8830e87e] info oneagentos : Starting to wait (blocking) for waitpid return, pid number = 3311904
2020-02-20 10:55:15.899 UTC [87b0f87e] info oneagentos : New connection on port 50000 received.
2020-02-20 10:55:15.899 UTC [87b0f87e] info oneagentos : Ping received: [HEALTHY:3311904] observedPid: 3311904, total ping count: 1
2020-02-20 11:05:16.336 UTC [87b0f87e] info oneagentos : Ping received: [HEALTHY:3311904] observedPid: 3311904, total ping count: 61
2020-02-20 11:15:17.704 UTC [87b0f87e] info oneagentos : Ping received: [HEALTHY:3311904] observedPid: 3311904, total ping count: 121
2020-02-20 11:25:19.074 UTC [87b0f87e] info oneagentos : Ping received: [HEALTHY:3311904] observedPid: 3311904, total ping count: 181
2020-02-20 11:35:20.412 UTC [87b0f87e] info oneagentos : Ping received: [HEALTHY:3311904] observedPid: 3311904, total ping count: 241
2020-02-20 11:45:21.877 UTC [87b0f87e] info oneagentos : Ping received: [HEALTHY:3311904] observedPid: 3311904, total ping count: 301
2020-02-20 11:55:23.255 UTC [87b0f87e] info oneagentos : Ping received: [HEALTHY:3311904] observedPid: 3311904, total ping count: 361
5 REPLIES 5
skrystosik
You see hosts in dynatrace? Or you don't see hosts / transaction & services?
Regards, Sebastian
Hello Sebastian,
No, ı'm not see hosts / transaction & services for my nodes.
And you are sure that your Kubernetes nodes have open network traffic to ActiveGate? (It's different communication than between ActiveGate and Kubernetes cluster for metrics collection).
Regards, Sebastian
It did not have access to ports 8443 and 9999. I'll try again by defining access permissions. Could that be the cause of the problem ?
But if there was an access problem, the pods would log the connection-related error.
I did not understand.
For ActiveGate should be 9999 (OneAgent => AG) from AG to DT Server 443/8443
Regards, Sebastian
