question
Roberto R. avatar image
Roberto R. asked ·
Top Errors Charted
Hi!
Is possible to "Pin to dashboard", or do something similar, this kind of informations for what concern the error details?
My aim is to have in a new dashboard the most frequent errors, like the image above.
I was trying to use also the USQL but the best that I was able to find was:
SELECT TOP (usererror.name, 10) AS "Error", COUNT(*) AS "Number" FROM usersession WHERE useraction.application IS "app_name" GROUP BY Error ORDER BY Number DESC
Thanks!
Roberto
dashboarderrorserror reporting
domenico b. avatar image
domenico b. answered ·
Hi Roberto,
you use custom chart. Search 5xx or 4xx in metrix fields :)
2 comments Share
Hi Domenico,
yes, I was thinking about it but I must use the "service" section for the custom chart.
At the moment I have different management zone configurated by only the single application rule. If I use service for charting, no information are displayed. In the management zone rule configuration I must add all the correct services for do this. Is it correct?
Anyway my aim is to show the top error 4xx 5xx and not only the count, for what that I saw at the moment is not possible :)
Roberto
0 Likes 0 · ·
Yes. My suggestion is to create automatic rules in order to tag your service and add tag to management zone to filter tiles base on your needs and/or add it to management zone.
0 Likes 0 · ·
Chad T. avatar image
Chad T. answered ·
@Roberto R. This is possible by creating a custom chart and selecting Applications > Count of errors by user Type, Error type and Error origin. see the screen shots:
In the last step you have the ability to further customize and filter down your chart. This will be pinned to any dashboard you desire. Let me know if you need any additional assistance.
-Chad
4 comments Share
Hello Chad,
Thanks for the feedback. I have already seen it, but it does not return the details of the HTTP error such as:
"HTTP 404: /bundles/fonts/slick.ttf"
I only have the type of error
Roberto
0 Likes 0 · ·
Even with the filtering of HTTP?
0 Likes 0 · ·
If you want to see that Multi-dimensional analysis: Errors and or the clicking into one of these errors and seeing the details surrounding it...
I would recommend tossing in a Request for Feature as the ability to pin this does not exist yet. For a solution you can put in place today... I would recommend using a markdown tile as such:
Clicking this link will take you right to the page you desire. but you will not see an overview on the dashboard. that is one drawback.
1 Like 1 · ·
Hello Chad,
thanks for the suggestions. Using a markdown tile for link the dashbaord is a good workaround, but I need the overview directly on the dashboard. I've opened a RFE for it.
Thanks for the support.
Roberto
1 Like 1 · ·
Ravi K. avatar image
Ravi K. answered ·
Hi Roberto,
I am looking for the same. I want to pull data for top 10 error in the application and pin it to dashboard. What is the status of your RFE ?
Ravi
Share
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services custom event alerts notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions diagnostic tools session replay permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
