Add log file to other process
henk_stobbe
DynaMight Champion
DynaMight Champion
Simple question, can I add a log file to an other process? (no java or .net)
KR Henk
3 REPLIES 3
ChadTurner
DynaMight Legend
DynaMight Legend
@Henk S. Yes you can. If Dynatrace does not automatically detect log files you can also add them into the definitions. You just need to access the process in question, select edit and navigate to log monitoring. From there you will be able to define the log name to detect. But, you must have log monitoring enable first!
-Chad
Hi Chad,
Dynatrace gave me a not allowed for a certain file , so that confused me. Now I also know about the config file to allow unknown logs...
Thanks for your reply,
KR Henk
Hey Henk,
Yes the detection has rules and can be a bit finicky. This document will detail the requirements and limitations.
https://www.dynatrace.com/support/help/how-to-use-dynatrace/log-monitoring/configuration/add-log-fil...
-Chad
