• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Dynatrace /
  • Dynatrace Open Q&A /
avatar image
Question by Jeff R. · Feb 27, 2020 at 01:37 PM · oneagent activegate documentation
Is OneAgent selection of AG based on load and latency?
Describing how OneAgents determine which AG to connect to, the page at the link below states that "If more than one such ActiveGate is available, OneAgents will try to switch between the available ActiveGates on a regular basis to achieve proper load balancing."
https://www.dynatrace.com/support/help/setup-and-configuration/dynatrace-activegate/basic-concepts/supported-connectivity-schemes-for-activegates/
I had previously thought (assumed) that the OneAgents would be checking network latency to the AGs and would pick the one with lowest latency (within AGs of a specific type, such as Environment AG). Is that not the case, or are BOTH load and latency taken into consideration?
Comment
AnuRanjan K.
People who like this
1 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Sebastian K. · Feb 27, 2020 at 02:42 PM
As I know this is only based on AG load, not latency. When we are making deployments, group of agents has access via network to only one AG. If there are some extra considerations here I would be happy to get such informations as well :)
Comment
AnuRanjan K.
1 Show 5 · Share
avatar image Jeff R. · Feb 27, 2020 at 03:18 PM 0
Share
If that is the case then my concern is that agents will often end up not connecting to the "local" AG (i.e., one in the same data center as the agent) but will instead be sending data to AGs that are located in other data centers... not very efficient from a network perspective
avatar image Sebastian K. Jeff R. · Feb 27, 2020 at 03:24 PM 0
Share
According to this doc, OneAgent will prefer AG that is closer. In such case this shouldn’t be issue for you.
avatar image Jeff R. · Feb 27, 2020 at 04:09 PM 0
Share
I understand the hierarchy of preference between the Environment and Cluster AGs and of these over a direct connection to the cluster, but that view of closeness does not relate to the actual network distance.... so when we have multiple Environent AGs (as we do) the documentation does not appear to state that the one that is actually closest or has the least latency will be selected.
avatar image Július L. Jeff R. · Feb 27, 2020 at 04:20 PM 0
Share
Latency might be very volatile. I think balancing is only dependent on the number of connections or on amount of data.
avatar image Jeff R. Július L. · Feb 27, 2020 at 04:32 PM 0
Share
Perhaps, although I would think that there would often be significant differences between geographically remove sites... so it surprises me that the algorithm does not take that into consideration... But thanks for confirming that it is based on load (connections & traffic volumes) only.
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
35 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
News article version and release page version do not appear to match
Changes to disk space requirements on Linux?
Settings that OneAgent connect directly to SaaS tenant when install ActiveGate
Dynatrace Proposed Design Assistance Required
After Changing Listening Port of Active Gate, how would OneAgent behave?
Forum Tags
mobile monitoring dotnet iis chat kubernetes servicenow amazon web services feedback mysql mainframe application rules rest api cassandra dashboard oneagent sdk cmc waterfall chart application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo opentelemetry integrations activegate auto-detection high five award uem webserver usql iib test automation license ios news migration management zones ibm mq web services notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming resource javascript appmon ai availability tipstricks automation extensions diagnostic tools session replay permissions search davis assistant auto-update faq documentation problem detection http monitors easytravel apdex network docker tags and metadata cloud foundry google cloud platform synthetic monitoring lambda process groups account usability dynatrace saas gui paas openshift key user actions administration production user actions postgresql synthetic locations upgrade oneagent security Dynatrace Managed user management python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting performance monitoring NGINX action naming geolocation linux nam installation error reporting database mission control apache slo mobileapp RUM php azure purepath davis scripting aix nodejs android
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
