Missing Metadata Kubernetes info in Openshift 4.2
DanielS
Hi, our customer is migrating from OKD (3.11) to OCP (4.2) in Openshift but as you can see in the images attached the Kubernetes Cluster and Kubernetes labels metadata is missing. Also when I go to Technologies can't see CRI-O but I can see it in the image.
I'm missing something or is a lack of functionality?
Also I think that CRI-O has a missing menu option because under Docker I can see my docker host in openshift 3.11 but can't see my Kubernetes Container Runtime Interface (CRI) for OpenShift Container Platform and Kubernetes,
replacing the Docker service.
The true delight is in the finding out rather than in the knowing.
michael_oxendin
Dynatrace Helper
Dynatrace Helper
Hi Daniel S.,
To get the information you are looking for, I would suggest using the Kubernetes integration. Also, I have linked a blog post below that will allow CRI-O container monitoring.
https://www.dynatrace.com/news/blog/get-automated-full-stack-visibility-into-your-cri-o-kubernetes-c...
Thank You,
Michael Oxendine
navin_sridharan
Newcomer
Piggy backing on similar request, could you please advise where CRI-O related metrics is being instrumented
