Management zone automation using Dynatrace REST
rswarnka
Helper
Hi, can we achieve automation of management zones like creation, updation using REST APIs?
3 REPLIES 3
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
Yes you can create and update management zones through config API.
Best greetings,
Wolfgang
jose-antonio_ra
Inactive
Hi Rajesh.
from Dynatrace API explorer, there are these options:
BR.
jose A
