CloudFoundry - Application Only Monitoring Vs Full Stack Monitoring
aslam_parveez
Newcomer
We are evaluating on App Only Monitoring for Cloud Foundry against to Full Stack Monitoring using Bosh Add On. Would like to know the benefits of each and when to opt for one over other.
michael_bonner
Dynatrace Helper
Dynatrace Helper
Hi Aslam!
We have a good high level comparison of the two here:
https://www.dynatrace.com/support/help/shortlink/capabilities-cf#full-stack-vs-application-only
This link also is branched from our base documentation hub for CF.
-Michael
I would also recommended reading the link, it will give you examples of when full-stack monitoring is the preferred approach over application-only monitoring and vice versa. ^.^
