How to create hostcustomproperties.conf file properly?
emanuele_longo
Participant
Hello guys,
I tried to create hostcustomproperties.conf in order to define metadata for my systems monitored without success.
I followed the guide: https://www.dynatrace.com/support/help/how-to-use-dynatrace/hosts/configuration/define-tags-and-meta...
AppName=easyTravel
Environment=Dev
Organization=D1P
Owner=john.doe@dynatrace.com
Support=https://www.dynatrace.com/support
I also restarted the dynatrace agent service but on DynatraceManaged I cannot see the metadata I previously added.
Please can anyone help me?
Regards
3 REPLIES 3
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
3 questions:
1. Is the file encoded in UTF-8?
2. Are you sure you have placed the file in correct directory and it has proper permissions?
3. Have you checked agent logs?
Senior Product Manager,
Dynatrace Managed expert
emanuele_longo
Participant
Hello Radoslaw,
thanks for your suggestion.
I resolved my issue.
The problem is due to %PROGRAMDATA% (I thought was C:\Program Files (x86)\dynatrace\oneagent\agent\conf) instead it is C:\ProgramData\dynatrace\oneagent\agent\config
Thanks a lot
your welcome, thanks for sharing details
