Db2 query plugin
maykon_salvi
Newcomer
Is there any plugin that I can use to run query in database for Dynatrace SaaS?
4 REPLIES 4
Mike_L
Dynatrace Guru
Dynatrace Guru
Mike_L
Dynatrace Guru
Dynatrace Guru
You can also use our Custom device API, but then the metrics will be placed on a custom device which in this case won't be consumed by Davis, the Dynatrace AI.
https://www.dynatrace.com/support/help/extend-dynatrace/dynatrace-api/environment-api/topology-and-s...
Mike
Mike
maykon_salvi
Newcomer
instead o fusing it. do we have any metric api that i can use to put? for example. i can run a query via shell script and run a curl to inject the data.
Yes. You can push metrics via our REST API after you gather the data in any way you like.
https://www.dynatrace.com/support/help/shortlink/api-custom-metrics
