Dynatrace SaaS - Executing custom-sql-query to get a value from database table and set custom-Alert
anil_yadav
Newcomer
Like AppMon give options to query a database table (AWS MSSQL RDS) and set the alert based on the value, how can it be done in Dynatrace SaaS?
3 REPLIES 3
Mike_L
Dynatrace Guru
Dynatrace Guru
anil_yadav
Newcomer
Could you please elaborate this line (from your given link answer): -
  1. device.stat_counter(key='count', value=StatCounterDataPoint( result[0], result[0], result[0], 1)
Here, how to declare/initialize/define device? StatCounterDataPoint is a custom method or what?
Thanks in advance,
AntonioSousa
