Unable to generate test problem through event API
AK
Pro
Hello Folks,
I'm pushing one dummy problem notification through event API and I'm using following URL to test "https://myenv.live.dynatrace.com/api/v1/events ".
Below is configuration done under HTTP monitor to generate test/dummy problem.
  1. The request URL is - "https:// myenv.live.dynatrace.com/api/v1/events"
  2. HTTP method - POST
  3. Additional HTTP Header - Authorization API token
  4. Request Body - { "eventType": "AVAILABILITY_EVENT",
"timeoutMinutes": 05,
"attachRules": { "entityIds": ["HTTP_CHECK-XYZ"] },
"source": "OpsControl",
"description": "XYZ service is Down" }
But, when I run this monitor the event/problem is not generated and logs entry says "POST https://myenv.live.dynatrace.com/api/v1/events  | Failed to resolve hostname for myenv.live.dynatrace.com : Search domain query failed. Original hostname: 'myenv.live.dynatrace.com ' failed to resolve 'myenv.live.dynatrace.com ' after 12 queries -> [/192.xxx.y.z:53] failed to send a query via UDP (no stack trace available)".
I have tested this under postman and successfully able to generate the problem with desired details.
I don't know why its not working when I configured it through HTTP monitor.
Can anybody please throw some light here.
Thanks...
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
So if I understand you right, you do post an external event into your own Dynatrace environment by using a Synthetic monitor?
It seems your private synthetic nodes can't resolve the Dynatrace domain.
best greetings,
Wolfgang
Lets me explain it like below.. (I have configured it for testing purpose only)
I want to generate test problem for one HTTP monitor and below is configuration done under same HTTP monitor,
  1. The request URL is - "https: //myenv.live.dynatrace.com/api/v1/events"
"description": "Service1 is Down" }
Note:- "HTTP_CHECK-XYZ" is entity ID of same HTTP monitor through which I want to post a problem notification.
Thanks...
