how can we monitor process group health into the Dashboard like the others Health widgets or via custom chart?
maykon_salvi
Newcomer
how can we monitor process group health from Dashboard? if not possible. Does Dynatrace developer plan to monitor them? basically what we would like to have is something which is showing under technologies tab into Dashboard.
pahofmann
You can do it via a custom chart.
All the metrics for the different process groups that are in the technologies tab are available as metrics and can be used in custom charts.
You can e.g. filter for the Technologies category and then search for your technology to get all availible metrics for it:
A Health tile for process groups is not available though.
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
ChadTurner
DynaMight Legend
DynaMight Legend
you cannot get a tile that is dedicated to the process group health like the hosts, mainly because multiple processes reside under that group. You can however create a custom chart that might look at .net failures and other metrics.
-Chad
