easyTravel not start on AWS linux
j_tran
Newcomer
I downloaded easyTravel for Dynatrace
I'm running both ubuntu and ec2 on AWS. I cannot get easyTravel to work on either Linux.
I ran ./runEasyTravelNoGUI.sh. When I try to hit the public IP with port 8080, nothing happened. I have all incoming ports opened on the host.
What can I send you to help troubleshoot?
Radu
Dynatrace Champion
Dynatrace Champion
Hi Joey,
From what I can remember you still need to 'start' EasyTravel by running a scenario. Instead of hitting the website straight away, try running the \weblauncher\weblauncher.sh script and hit port 8094 - does that open the web ui for you?
If so, you can run an EasyTravel scenario from there and that should start the app on port 8080 and 8079.
Best regards,
Radu
j_tran
Newcomer
Solved.
I couldn't get easyTravel to work on the free AWS Linux AMI (both ec2 and ubuntu).
EasyTravel works fine on other environments (i.e. Ubuntu installed).
