Does monitoring 3rd party services still work?
Hello I would like to know if this part of the documentation is still valid:
https://www.dynatrace.com/support/help/how-to-use-dynatrace/transactions-and-services/monitoring/mon...
Thank you!
Yann Buccellato
3 REPLIES 3
pahofmann
Yes that documentation is still valid, though the screenshots could use an update.
There also is an API now for more flexibility in splitting ob requests to public networks.
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
ChadTurner
DynaMight Legend
DynaMight Legend
Hello @Yann B. This is still available within the Dynatrace platform. However, it has been renamed. If you go to Transactions and services and filter by External Services, you can select external hosts or 3rd party (external) services. From there you will see a list of 3rd party urls/transactions your hosts are performing.
-Chad
Dynatrace always surprise me for the better! Thank you for the answear Chad!
