Retrieve UI-URL to service over API
We are using the dynatrace api to extract some performance data for specific services. What we also want to have is a link to the dynatrace webui for a specific service (Like you get a Build-URL for a jenkins job over the jenkins api). Is there already a way to do this?
I couldn't find anything in the services endpoint and I think it wouldn't be a good idea to create this link on my own code as it could change over time.
regards,
Gerald
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
Hi Gerald,
You can use our generic navigation route to reach any entity:
<YOUR_DT_BASE_URL>/ui/nav?meid=<SERVICE-ID>
This also works for hosts, processes etc.
I think that will solve your requirement 🙂
Best greetings,
Wolfgang
