question
Jadumani J. avatar image
Jadumani J. asked ·
Magento: php-cli process not being monitored
I'm running Magento using LAMP stack. DT detects a process "PHP-CLI" but gives an error that "Dynatrace OneAgent has no access to this process. Restart the process with PID(s) 24384, 24378, 24380, and 24382 to start its monitoring"
When I killed the above process, they restarted automatically as the cron job (using the process) is scheduled. Still then I'm getting the same error. I restarted apache, still no luck.
Anything I can do make it work?
The meta data for the process is as below:
Command line args: /usr/bin/php7.2 /var/www/html/bin/magento queue:consumers:start product_action_attribute.website.update --single-thread --max-messages=10000
EXE name: php*
EXE path: /usr/bin/php*
Main technology: PHP
PHP script: /var/www/html/bin/magento
PHP working directory: /home/magento
oneagentprocess groupsphp
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
Do you have selinux or something like that co figured? If prices is sandboxed and started via cron it may be inaccessible by Agent.
I suggest downloading support archive from this agent and check logs. There may be more information about issue you have here. If there will not be any clue I suggest support ticket. Guy from dynatrace can enable some debug flags and collect more data :)
1 comment Share
Thanks.
No, SELinux is not configured. The cron job basically runs to check price rules, reindexing, alerts, emails etc. I downloaded the process support archive (attached) but not able to interpret much.
PHP-CLI process support archive
monitoring_state.json file reads as below:
"state": {
"injectionFailed": false,
"outdatedAgent": false,
"processAvailable": true,
"noInjectionAvailable": false,
"missingAgents": [
"PHP"
"processGroupConfigState": {
"state": "CONFIG_ACTIVE",
"isBadVersion": false
"extendedInjectionSupportState": {
"injectionSupportState": "SUPPORTED"
"infrastructureOnly": false,
"agentReportedState": {
"agentInjectionInformation": {
"actualAgentInjectionInformation": {
"configRevision": 1585429818098,
"processAgentInjectionInformation": {
"agentPresent": true,
"agentVersion": "1.187.154.20200303-135131",
"mmapPresent": true
"specialAgentInjectionInformation": {
"injectionDecisions": {
"PHP": {
"agentType": "PHP",
"injectionDecision": "INJECTION_DECISION_AGENTTYPE_BASED_INJECTION_DISABLED",
"injectionDecisionId": 10,
"injectionStatus": "INJECTION_STATUS_PENDING"
"injectableTechnologies": {
"PHP_CLI": {
"type": "PHP_CLI",
"version": "7.2.29"
"missingMonitoringReasons": {}
"agentInjectionInformationPerPid": {
"infoPerPid": {}
"fallbackConfigState": {
"aixKernelExtensionsSupport": false
"isBlacklisted": false,
"isManuallyInjected": false,
"hasRestartableParentProcess": false,
"osType": "OS_TYPE_LINUX",
"lastSeenDiffMs": 216976,
"agentReportedPotentiallyInjected": false
"extendedProcessGroupConfigState": {
"agentTechnologyTypes": [
"PHP"
"agentAvailable": true,
"areAllAgentsInjected": false,
"isRestartRequired": true,
"pgInjectionRuleCheck": {
"input": {
"PG_ID_CALC_INPUT_KEY_PHP_CLI_SCRIPT_PATH": "/var/www/html/bin/magento",
"PG_ID_CALC_INPUT_KEY_PHP_CLI_WORKING_DIR": "/home/magento",
"PG_ID_CALC_INPUT_KEY_EXE_PATH": "/usr/bin/php*",
"PG_ID_CALC_INPUT_KEY_EXE_NAME": "php*",
"PG_ID_CALC_INPUT_KEY_COMMAND_LINE_ARGS": "/usr/bin/php7.2 /var/www/html/bin/magento queue:consumers:start product_action_attribute.website.update --single-thread --max-messages\u003d10000"
"result": "noMatch"
"osAgentInjections": {
"AGENT_TYPE_DOTNET": [
"IIS"
"AGENT_TYPE_JAVA": [
"ON"
"AGENT_TYPE_PHP": [
"APACHE",
"PHP_FPM"
"AGENT_TYPE_LOG_ANALYTICS": [
"ON"
"AGENT_TYPE_NGINX": [
"ON"
"AGENT_TYPE_IIS": [
"ON"
"AGENT_TYPE_PLUGIN": [
"ON"
"AGENT_TYPE_NET": [
"ON"
"AGENT_TYPE_NODEJS": [
"ON"
"AGENT_TYPE_APACHE": [
"ON"
"AGENT_TYPE_GO": [
"ON"
"AGENT_TYPE_SDK": [
"ON"
"hostInjections": {},
"hostExperimentalInjections": {},
"mergedInjections": {
"ON"
"ON"
"AGENT_TYPE_IIS": [
"ON"
"ON"
"AGENT_TYPE_GO": [
"ON"
"AGENT_TYPE_SDK": [
"ON"
"AGENT_TYPE_PHP": [
"APACHE",
"PHP_FPM"
"AGENT_TYPE_NET": [
"ON"
"ON"
"ON"
"ON"
"IIS"
0 Likes 0 · ·
