question
Steven F. avatar image
Steven F. asked ·
Having issues tracing problem with CPU exhaustion
Have an issue where my DefaultAppPool CPU consumption shoots up to 100% under fairly low load.
Looking in Dynatrace Under the DefaultAppPool I have Background CPU showing as the 100% and within that I have an entry for ArtificalEntryPoints.CrossDomainRemoting .NET | Ruxit
There are then entries under this but nothing stands out as obviously causing the issue, is this just a usual Dynatrace entry and it is the just within the code beneath or does the Cross DomainRemoting point at something more request/networky?
IIS .NET C# on windows 2012
web performance monitoringiis
1 Answer
Chad T. avatar image
Chad T. answered ·
Can you share with us any images so we can help dig deeper into this with you?
Share
