Unmerge services
henk_stobbe
DynaMight Champion
DynaMight Champion
I understand you can merge services, but is it also possible to unmerge (if needed?),
KR Henk
pahofmann
Yes you can, just go to: Settings -> Server-side monitoring -> Merged service monitoring and edit or delete the merged service:
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
Exactly as Patrick showed!
-Chad
