question
Manivannan G. avatar image
Manivannan G. asked ·
Can some help me with steps on how to build a unbreakable CICD pipeline with Azure Devops?
I am trying to build an automatic self healing CICD pipeline on Azure devops with Dynatrace integration. .
Previously there was an extension(Dynatrace unbreakable pipeline) in Azure marketplace and currently it is not available. Can we get some guidance on how to implement this pipleine ?
continuous deliveryazure
1 Answer
Andreas G. avatar image
Andreas G. answered ·
Hi. The Unbreakable Azure DevOps Pipeline would be something you implement using Keptn. Keptn provides automated Quality Gates which you can call from Azure DevOps. We do have a couple of examples and customers who are using it. I suggest you sign up for our Keptn slack and send the question in the #help channel. We can then connect you with others who have already done the implementation: https://join.slack.com/t/keptn/shared_invite/zt-716xqbhz-w2xUeCpC1AgMMweGOYlPrA
Share
