In the environment of kubernetes(AWS EKS), the traffic information of the container cannot be obtained.
kubernetes(AWS EKS) uses cni by default for network communication
https://github.com/aws/amazon-vpc-cni-k8s
/usr/bin/kubelet --cloud-provider aws --config /etc/kubernetes/kubelet/kubelet-config.json --kubeconfig /var/lib/kubelet/kubeconfig --container-runtime docker --network-plugin cni --node-ip=x.x.x.x --pod-infra-container-image=602401143452.dkr.ecr.us-west-2.amazonaws.com/eks/pause-amd64:3.1 --node-labels=role=generic-worker,eks.amazonaws.com/nodegroup=generic-worker
Does it not support docker network monitoring under Kubernetes?
Answer by Dariusz G. ·
Traffic information in containers is a very complexed topic, since there are too many CNI specific implementations. The plan for now is to provide topology visibility of containerized environments, and then look for a generic solution to monitor the traffic. There's no ETA specified at the moment.
Deploying DT Managed OneAgent in OpenShift Online 3 environments (non-privileged containers)
X-dynatrace header getting removed from tomcat process
Plugin execution timeout for docker technologies on kubernetes
Host directory /opt/dynatrace/oneagent is accessible from all containers
Using OneAgent Operator for app-only injection via webhook on a monitored host
