question
T I. avatar image
T I. asked ·
Private Agent - Certificate for the HTTP client
For private agent - We are noticing that as the test execute they make calls to google and api.google.
We would like these outbound calls to a root certificate of the organisation. Where can I set this?
We used to use proxy and recently switched to Zscaler. For proxy we used to add the information in the custom.properties. For Zscaler the access is based on a cert.
Moses.
synthetic locations
1 Answer
Chad T. avatar image
Chad T. answered ·
If I understand correctly, You would need to add the cert into the activegate that is performing the internal Synthetic test.
1 comment Share
Currently the first calls that the synthetic tests make is to invoke chormium with a new tab. This is making a call to google api. This call is failing because the outbound connection doesnt include the certificate.
Earlier we used to work around this by adding the [synthetic] tag in custom.properties and giving the proxy information.
The ask is if there is a way to provide / add the cert to any outbound calls. or better yet make a change such that the outbound call doesnt happen in Private agent setting.
Moses.
0 Likes 0 · ·
