Getting started with building Synthetic Monitoring Plugin
rswarnka
Helper
Hi, I need to build a custom ActiveGate plugin to monitor the URLs. What are my options to get started?
3 REPLIES 3
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
Take you hands-on here: https://www.dynatrace.com/support/help/extend-dynatrace/plugins/activegate-plugins/introduction/writ...
There are plugin examples that you can start with.
And I guess here's the API you want to consume with plugin:
https://www.dynatrace.com/support/help/extend-dynatrace/dynatrace-api/environment-api/synthetic/exte...
Senior Product Manager,
Dynatrace Managed expert
AlexanderSommer
Dynatrace Champion
Dynatrace Champion
Can't you use HTTP monitors? Which protocol do you want to support?
We are trying to poll applications behind SAMLv2 SSO. Also, customer is expecting to avoid DEM consumption.
