Azure event stream
henk_stobbe
DynaMight Champion
DynaMight Champion
For Azure to be able to send its event stream, the documentation states:
One or more designated ActiveGates with valid TLS certificate
I assume an "environment" activeGate is needed that is connected to the internet?
(I am asking about Managed)
KR Henk
ChadTurner
DynaMight Legend
DynaMight Legend
Yes, You will need an activegate that has the Azure modules enabled. If you go into your "Deployment Status" > "Activegates" it will list all your environment activegates and you can take a look at what modules are enabled.
-Chad
