question
Mahima G. avatar image
Mahima G. asked ·
Extract host names from last 90 days till now using API?
Want to extract the details of host names from last 90 days till current date using API, can I do it?
host monitoringmanagement zones
1 Answer
Chad T. avatar image
Chad T. answered ·
yes you can via the Environment API.
2 comments Share
I have some hosts, where one agent stopped working, so would I not be able to extract that hosts?
1 Like 1 · ·
Sure they are still receivable through the API, just use a past timeframe where OneAgent was running back then.
2 Likes 2 · ·
