question
Pujith A. avatar image
Pujith A. asked ·
Dynatrace Plugin for Jenkins - facing issue with Dashboard created in Jenkins
Groovy Script
node('master') {
stage('creatingEvent') {
// create event
// createDynatraceDeploymentEvent(entityIds: [[$class: 'Service', entityId: 'SERVICE-3A7675E372F5CBA9']], envId: 'Dev', tagMatchRules: [[meTypes: [[meType: 'SERVICE']], tags: [[context: 'KUBERNETES', key: 'ABCD', value: '1234567']]]]) {
//some block
stage('Test'){
recordDynatraceCustomSession entityIds: [[$class: 'Host', entityId: 'HOST-BDFA365380EFA92B']], envId: 'Dev', testCase: '', timeframeStart: 1587605159000, timeframeStop: 0
perfSigDynatraceReports envId: 'Dev', metrics: [[metricId: 'com.dynatrace.builtin:service.requests'], [metricId: 'com.dynatrace.builtin:host.disk.usedspace']], nonFunctionalFailure: 1, specFile: ''
Response:
[Pipeline] perfSigDynatraceReports
[PERFSIG] getting available time series definitions [PERFSIG] process available specifications [PERFSIG] getting metric data from Dynatrace for [PERFSIG] Timeseries com.dynatrace.builtin:service.requests has no data points [PERFSIG] created 0 DashboardReports
[Pipeline] }
[Pipeline] // node
[Pipeline] End of Pipeline
de.tsystems.mms.apm.performancesignature.dynatracesaas.rest.CommandExecutionException: error while querying timeseries data: {"error":{"code":403,"message":"The query has returned too many entities. Please use filter options."}} Stacktrace: de.tsystems.mms.apm.performancesignature.dynatracesaas.rest.ApiException: {"error":{"code":403,"message":"The query has returned too many entities. Please use filter options."}}     at de.tsystems.mms.apm.performancesignature.dynatracesaas.rest.ApiClient.handleResponse(ApiClient.java:251)     at de.tsystems.mms.apm.performancesignature.dynatracesaas.rest.ApiClient.execute(ApiClient.java:223)     at de.tsystems.mms.apm.performancesignature.dynatracesaas.rest.DynatraceServerConnection.getTimeseriesData(DynatraceServerConnection.java:133)     at de.tsystems.mms.apm.performancesignature.dynatracesaas.rest.DynatraceServerConnection.getTimeseriesData(DynatraceServerConnection.java:115)     at de.tsystems.mms.apm.performancesignature.dynatracesaas.DynatraceReportStepExecution.lambda$null$13(DynatraceReportStepExecution.java:304)     at java.util.stream.Collectors.lambda$toMap$58(Collectors.java:1321)     at java.util.stream.ReduceOps$3ReducingSink.accept(ReduceOps.java:169)     at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1382)     at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481)     at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471)     at java.util.stream.ReduceOps$ReduceTask.doLeaf(ReduceOps.java:747)     at java.util.stream.ReduceOps$ReduceTask.doLeaf(ReduceOps.java:721)     at java.util.stream.AbstractTask.compute(AbstractTask.java:316)     at java.util.concurrent.CountedCompleter.exec(CountedCompleter.java:731)     at java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:289)     at java.util.concurrent.ForkJoinPool$WorkQueue.runTask(ForkJoinPool.java:1056)     at java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1692)     at java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:157)
    at de.tsystems.mms.apm.performancesignature.dynatracesaas.rest.DynatraceServerConnection.getTimeseriesData(DynatraceServerConnection.java:136)     at de.tsystems.mms.apm.performancesignature.dynatracesaas.rest.DynatraceServerConnection.getTimeseriesData(DynatraceServerConnection.java:115)     at de.tsystems.mms.apm.performancesignature.dynatracesaas.DynatraceReportStepExecution.lambda$null$13(DynatraceReportStepExecution.java:304)     at java.util.stream.Collectors.lambda$toMap$58(Collectors.java:1321)     at java.util.stream.ReduceOps$3ReducingSink.accept(ReduceOps.java:169)     at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1382)     at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481)     at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471)     at java.util.stream.ReduceOps$ReduceTask.doLeaf(ReduceOps.java:747)     at java.util.stream.ReduceOps$ReduceTask.doLeaf(ReduceOps.java:721)     at java.util.stream.AbstractTask.compute(AbstractTask.java:316)     at java.util.concurrent.CountedCompleter.exec(CountedCompleter.java:731)     at java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:289)     at java.util.concurrent.ForkJoinPool$WorkQueue.runTask(ForkJoinPool.java:1056)     at java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1692)     at java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:157) Finished: FAILURE
configurationextensionscontinuous delivery
1 Answer
Andreas G. avatar image
Andreas G. answered ·
Hi. The error message indicates that there are too many requests coming back from your query because you only selected a metric but didnt specify the entityId when calling perfSigDynatraceReports. Please have a look at the documentation of that plugin which is supported by our partner T-Systems: https://github.com/jenkinsci/performance-signature-dynatrace-plugin/blob/master/dynatrace/README.md
Also - as this is a partner supported plugin you can send them an email as indicates on that github readme.
Another option is to move towards our Keptn Quality Gate implementation and using our Keptn Jenkins Library. Here is a link to a tutorial: https://github.com/keptn-sandbox/keptn-jenkins-library/
Share
